SOURCE: our pool water is yellow and think it is because low chlorine
Add more salt and no salt strips only chlorine
There is also some chlorine called super chlorine that would work better
SOURCE: my intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
SOURCE: My intex saltwater system pump is beeping
Yes, and be sure to keep up with your pH as it will want to rise slowly over time when using a salt water chlorine generator.
SOURCE: Intex salt water chlorinator 56602
First of all 91 is low salt content not too much
Are you checking your salt level with a test strip
You need to be at 3000ppm anything under 2800ppm can trigger an alarm and not produce enough chlorine.
Same thing if you are over 3600ppm
all manuals just give you an amount to start with but it is up to you to fine tune it
After adjustments you need to filter only for 24 hours before trying to generate chlorine
SOURCE: Low salt alarm on Intex system
I had the same problem and my father just kept adding salt wo telling me and it kept saying low salt-I called intex they said to clean the cell with vinegar as instructed in book, and if that didnt help to call back for a warranty claim on the unit bc I just purchased mine in June. I am currently waiting on it to come in. We had to drain half the pool and refill with water and start over. be careful!
