Hotel tv unlocking
SOURCE: How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
SOURCE: Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
SOURCE: stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
SOURCE: 32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
