SOURCE: garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
SOURCE: Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
SOURCE: garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
