Re: Why valume go up by it self and all the inputs dont...
Main system control memory IC fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sounds like the main system control memroy IC is faulty.
Contact any service technician to confirm it. This IC is at the main board of the TV.
First take the Batteries out of your remote control to see if the T.V. is still changing channels or not. If it stops changing the channels and volume, try opening the remote with a knife and clean all the pads with rubbing alcohol to prevent sticking buttons. Be careful if using a remote with a roller ball.
You shouldn't need the license plate lights to work to make your trailer lights work. Chances are that there is an issue with the wiring it's self. On my father 94 pick up the wiring is spliced directly in the taillight wiring. If your taillights work there shouldn't be an issue with the trailer lights. Start by checking or remounting the ground wire attached to the wiring harness. If that isn't the issue test the input of the harness followed by the output. If there is input but no output you need to replace the harness. Try the CURT 55379 you can purchase this by visiting one of their retailers by clicking here.
i dont understand your question but as per by guess i sujest to you kindly chek the all valume key or shortkut key some time it is not working properly .
There are two lines leading into the unit, the high side aND THE LOW SIDE. tO ADD FREON you need to add a valve to the low side line. But if you have a leak that indicates that moisture is in the unit and you need to pull a valum to remove the moisture before ADDING ANY FREON. There are as last known three types of freon, R22, R134a and this last one I dont even know the name.
