Lets have a look at rear wall of freezer, is there frost building up?
Usually in top freezers the cold air
settles to bottom and you don't notice fresh food section until about a day. If frost is building open fresh food sections door and in control panel=>
CLICK HERE see item 257 in photo? That is
WR9X565 or
311082 Defrost Timer Just below that is the control panel cover and you should have a small plastic plug covering a hole just below the defrost timer. Pry plastic plug out and using a flathead screwdriver turn the defrost timer clockwise slowly. Once you hear the compressor and fans stop stop
turning timer and about a minute later you should hear some crackling noise coming from freezer. Allow to stay like that for up to 30 minutes and timer should come out of defrost and compressor and fans should start again on their own. If this action caused defrost then replace the defrost timer. If that does not seem to cause defrost the we need to go to step two, unplug and place items in a cooler or
alternate refrigerator and use a hair dryer to assist in melting the ice behind rear panel. Remove rear panel in back of freezer and see =>
Freezer Components item's 621 and
WR51X10038 or
880036 Defrost Heater AssemblyYou will need to remove rear panel and work with refrigerator unplugged from power. On this=>
Page watch how to test your defrost element just beside a photo of the timer. Most times I replace the defrost thermostat while inside freezer wall but I will let you try this first and please respond and rate, Thanks, Sea Breeze
WR51X10038 or 880036 Defrost Heater Assembly
