Warning you may have to test electrical circuits with the power live .Is there water flowing into the connection on the unit ? If not look for shutoffs or a crimped supply line. If you have water pressure You will need to know how to an electrical tester or multi meter to test the water inlet valve. You can test for voltage on the solonoid while someone activates the switch for water If you have voltage when the switch is activated the inlet valve could be bad or the tubing feeding the dispenser is frozen or pinched you can loosen the water line that goes to the refrigerator to check for flow with switch activated If you have no flow replace inlet valve if you have flow check that the waterline is not frozen crimped or pinched.If no voltage appeared during the voltage test , Test the switch and wiring and repair as necessary.
