Nikon N2020 35mm SLR Camera Logo
A
Anonymous Posted on Jul 31, 2014
I have a nikon n2020, just bought used. Everything works fine except the shutter. No matter the speed or program I set it to, the speed seems locked at about a 1/2 second or 1 second. New batteries, new film, exercised the shutter quite a bit, cleaned it. Still no change.
pontelemon
Level 3:
  • Master 538 Answers
  • Posted on Jul 31, 2014
pontelemon
Master
Level 3:
Answers
538
Questions
0
Helped
175931
Points
1223
Remove top cover. Make sure shutter speed dial is connected with contacts.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Sep 19, 2008
SOURCE: nikon FE shutter speeds problem
I don't know, but it's worth a try. I took mine to the camera store, because my shutter wouldn't even work anymore, even with fresh batteries in it. He again tried new batteries, and turned the shutter speed knob from Automatic all the way over to "B" for Bulb, and back to the Auto. Guess What! I haven't used the camera in 3-5 years because I thought it was broke and going to need factory repair. Well, this tricked worked for me. I was so thrilled, because my daughter wanted some double exposures and special filters shots for her wedding. Also the weight of the camera I couldn't handle anymore with a health problem, so I went to digital, but would love a Nikon good digital.
Good Luck!
welsberr
Wesley Elsberry
  • 25 Answers
  • Posted on Sep 25, 2008
SOURCE: Nikon F50
It is possible to damage Nikon SLRs by attaching them to certain older pieces of equipment. There are two main issues that you may encounter.
There are a series of contacts inside the lens mount that must be in good condition for correct operation of the camera. If the older gear causes these to bend or break, the camera will require repair. Look inside the lens mount using a flashlight to see if there is any sign of scraping or that the contact pins look damaged.
Many Nikon SLRs have a ring on the outside of the lens mount that has a small tab sticking up. The ring is supposed to rotate freely and the tab should interface with part of a Nikkor lens of AI-S or AF vintage. Earlier non-AI-S lenses or accessories could compress the ring or break the pin or both. If you can get the ring to rotate freely again, you might be able to get the camera to function. If the tab is broken or the ring is stuck or both, your camera will need professional repair.
Anonymous
  • Posted on Dec 26, 2009
SOURCE: My Nikon N2020 will not open to insert film
life up on manual film rewinder to release the the back to load film
Anonymous
  • 302 Answers
  • Posted on Feb 03, 2010
SOURCE: Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Anonymous
  • Posted on Aug 31, 2010
SOURCE: nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting). Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
1helpful
Shutter button wont go down on my N2020 nikon
Make sure the shutter isn't locked. Lift the ring around the shutter button and turn it to something other than the "L" for lock position.
If you need a manual, you may download a copy from here.
1helpful
Shutter button will not go down on my N2020 nikon
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
1helpful
Camera - Nikon N2020, Problem is shutter curtain is locked in the closed position. Camera works in all other aspects but film is not exposed.
From what you've given, it sounds like the shutter is fried. If you're wanting to keep the camera, and use it, you'll need to contact a repair technician and have them take a look at it for a repair estimate - assuming it's able to be repaired. Estimates will run you around $35 most places, if there's no shop near you KEH Camera which has a website is quite good. But, the N2020 has an electronic shutter which was never truly intended to be replaced, and no longer manufactured by Nikon, so the only source of them is scrounged from other cameras that have been scrapped for other reasons.
The N2020 is currently available online (ebay and others) for $5-20, so it'd probably be much cheaper to do this, than repair yours. I picked up a never used example of the 2020 with manuals, paperwork, and box on ebay for $10 a couple of years ago.
The same thing just happened to my Nikon FE, and my estimates have been ranging anywhere from $105-145 to get it fixed, so the decision of whether to repair or replace if really left up to you. But, as I said often replacement is cheaper than repair, unless you have some attachment to your camera (which I do, and which I'll have repaired).
Aug 24, 2011 • Photography
I purchased some replacement AAA batteries for the camera. Nothing happens when I depress the shutter button. The camera is a Nikon N2020 AF. It has not been used for quite awhile. The batteries used...
Happy ending to this saga of the Nikon N2020 AF. I went to Walmart and purchased some real photo grade batteries. At first the result was the same, no apparent change, dead camera. I left the batteries in the camera overnight. The next day I tried depressing the shutter button with the camera turned on to S for single shot, and to my amazement the camera came alive! I don't know why or how but now it works and I don't have to bring it in for servicing. Today we will be off to the local zoo to take some shots. Can't wait. Thanks for all the comments and suggestions.
I installed new batteries in my camera. I turn the on knob and camera does not operate. Something wrong with power system Contacts are clean, new batteries Nikon N2020
"Turn the on knob"? You turn on the N2020 by lightly pressing the shutter release button. Do the meter indicator LEDs inside the viewfinder light up when you lightly press the shutter release button?
My nikon d60 just started giving out blurry pictures no matter what setting it is on. The subject must be completely still to get any good shots. It use to not do this, what can I do?
A few basic checks Are you in full auto mode or some other shooting mode? Try different modes and see if any work. Does the shutter speed seem slow - like you can hear it cl - ick. When photographers want a blurry effect, slowing down the shutter is often used. Change mode or set a faster shutter speed. If none of these lead you anywhere, the imaging system that scans the imaging chip may be faulty. that's not a home repair.
Nikon F3's light meter always underexposed
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
