Andis Agc Single-speed Clipper Lightweight Dog Pet Grooming Clippers Logo
I
Ingrid Freedman Posted on Jul 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The mounting hinge will not raise on my clippers when I push up on the button below the blade
This is a very new purchase the mounting hinge did raise before now seems to have stopped working
danielle hand
Level 1:
New Friend:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Feb 05, 2015
danielle hand
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
16
Questions
0
Helped
15512
Points
39
The springs in them sometimes aren't connected correctly. You might have to connect them properly or just buy new springs.
Anglia Clipper Services
Level 2:
  • Expert 193 Answers
  • Posted on Aug 14, 2014
Expert
Level 2:
Answers
193
Questions
0
Helped
83682
Points
240
Whilst pushing the release button (latch) you must also pull the front of the blade away from the clipper.
1helpful
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
tip
Why You Shouldn't Swap Small Clipper Blades Between Dog Clippers
Although dog clippers manufacturers claim that their clipper blades are universal (fit other dog clippers), they work best on the dog clippers they were designed for.
The socket (clipper blade), the hinge assembly and blade drive assembly (dog clippers) vary from manufacturer to manufacturer. If you are using different brands of clipper blades on different brands of dog clippers, there will not be a perfect fit.
HINGE ASSEMBLY
The hinge assembly secures the clipper blade (via the blade socket) to the dog clippers.
If the hinge assembly is not regularly replaced, your clipper blades will start to rattle on your dog clippers. The ears on the clipper blade socket are constantly rubbing against the metal hinge assembly, which consequently causes wear on both the socket and hinge assembly. You must ensure that there is a snug fit between the clipper blade socket and the hinge assembly or the blade will eventually rattle.
On average, if a groomer is clipping 8 dogs a day, the hinge assembly will probably need replacing every 12 weeks.
When replacing the hinge assembly, make sure that the screws are secure because if they are too loose the clipper blade will not cut correctly or not at all.
It is not advisable to try to adjust the ears on the socket to enable the clipper blade to fit the hinge assembly, because you will risk breakage which will render the blade redundant until you get the socket replaced by a sharpening professional. The best person to adjust clipper blade sockets is an experienced clipper blade sharpener because he has the relevant tools and should the socket snap, he has spares.
BLADE DRIVE ASSEMBLY / BLADE LEVER
The plastic lever on the blade drive assembly locks into the cutting blade and drives it backwards and forwards.
Problems occur because the black plastic lever is constantly rubbing against the metal cutting blade; so consequently, the plastic will gradually wear away. Once the lever is worn, the cutting blade won't be driven side to side as much as it should.
If the blade drive assembly is not regularly replaced, the clipper blade will leave tram lines in the coat, pull at the hair, the dog clippers will sound noisier and the clipper blade will eventually, stop cutting.
On average, if a groomer is clipping 8 dogs a day, the blade drive assembly will probably need replacing every 6 - 8 weeks.
If your blade drive assembly is worn, your newly sharpened blades will not cut because the cutter blade is not being pushed along the whole width of the clipper blade (it is more noticeable on blades where the teeth are further apart - 3,4 5 & 7). If this is the case, we would strongly recommend that you replace your blade drive assembly.
on Feb 28, 2020 • Dogs
How do I put the blade on my Ostis PowerMax clippers? I have tried with it on and off with no success. Thank you.
The blade release should be under the heel of the blade, just below where the blade tongue hinges. You normally only need to press it when removing the blade, when snapping the blade shut it is mostly not necessary to push it. They are a bit like a door latch that self lock when closing.
1helpful
I just recieved a new Oster Golden A5 single speed from Amazon. The clippers worked fine with the no. 10 blade that was mounted on clipper. I removed the blade and now I can't get it back on or the 4f...
ok the blade latch only holds the blade into place.
the hinge assembly which the latch sits behind needs to be open, there is a silver piece with two ridges on, place a flat bladed screwdriver behind the hinge and this will lever open you can then slot the blade onto the hinge and close shut with the clipper running.
2helpful
How do you put on a blade when you took it off?
There is a picture of an oster clipper in the picture so I assume you are talking about an A5 style blade/clipper. Hold the clipper with the hinge facing you, if the hinge is open, then turn the blade so the blade number is facing up and slide it onto the open hinge, start the clipper and push the blade down to shut it. If the hinge is not open, prize it open with a flat head screwdriver. www.sheaeaseltd.com
Blades fell off oster dog clippers but can't fit them back on. Please help !!
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
www.sheareaseltd.com
1helpful
How do I put size 4 blade on clipper
The A5 clipper should have a locking hinge the hinge should be open and slide the clipper blade onto the hinge, now push on the clipper blade bachward and it will snap on. if you don't hear a snap sound the hinge on the clipper maybe worn out and don't have no spring tension.
2helpful
Can't put on a new blade
start the clippers then slide the blade onto the tongue of the hinge assembly , now push the blade into the clipper don't be afraid sometimes they can be tight from new,
Just make sure the two screws either side of the hinge are tight.
1helpful
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
1helpful
2answers
Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Top Andis Pets - Others Experts
Kardoc
Muhammad Tanveer
Sierra
Sierra
Level 1 Expert
Are you an Andis Pets - Other Expert? Answer questions, earn points and help others
