Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
