Televison & Video Logo
A
Anonymous Posted on Jul 15, 2021
Hi my kid accidentally pressed a unknown button on the while we were watching movies on USB port and the key lock is on while the TV is on USB port and there is no remote,key
Abdul Rasheed
Level 3:
Master:
  • Master 567 Answers
  • Posted on Jul 15, 2021
Abdul Rasheed
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
181653
Points
1403
Try doing a hard reset by removing the USB drive. Switch the off the TV and remove the power cable from the power outlet. Let it sit for an hour or longer. Then plug it in and turn the TV on without the USB drive. If not OK you need to unlock a "child lock" using the remote.
My toddler was playing with the remote while we were watching a movie from a usb I'm unaware of the button he pressed but the tv refuses to recognise the usb how do I fix this
Google
make model manual
or
make model reset
or
make model USB
Don't let toddlers play with remotes, as they can accidentally find hidden features. Or take the batteries out, and they will soon get bored.
Various generic ideas in this link. Google knows everything!
https://www.google.com/search?q=tv+refuses+to+recognise+the+usb
Maybe the toddler reformatted the drive?
How can we play video from a USB device? Why can we not download more apps???
Shop for tv How can we play vide... on Google
WD TV® Media Player
$109.99
Staples
(165) Hauppauge Computer Ha...
$84.99
Dell
(400) C2G 29351 Micro USB to...
$21.23
Sears Audio?Technica ATR2USB 3.5...
$13.95
zZounds Diamond ATI TV Wonder H...
$39.92
B&H Photo-Vi...
(12) Search Results
    USB Flash Drive Movies on your Flat Screen TV - YouTube
    ? 4:10
    https://www.youtube.com/watch?v=ge4Wo9FQf8w
    Oct 5, 2014 - Uploaded by 21NorthMedia
    How to watch Movies & Photos from your USB Flash Drive via the USB Port on your Flat Screen TV.
    Watch a movie on your TV from a USB drive. - YouTube
    ? 2:40
    https://www.youtube.com/watch?v=jOhvbdVkPaM
    Nov 10, 2012 - Uploaded by DIYallday
    I'm trying to play movies from my USB port, but when I plug it I can't .... My LG 47" TV will recognize and open the flash drive, but shows empty.
HOW DO I USE THE USB PORT TO PLAY MOVIES
Some TV models have a USB port so that users could play videos and movies from USB on TV. You can try the following steps:
1. Connect your readable and writable USB drive to computer
2. Copy your movies to USB drive and then disconnect your USB drive from computer.
3. Connect the USB device to the Sony TV USB port. Turn on the connected USB device if necessary.
4. Press the HOME button on Sony remote controller to open the menu.
5. Enter the target USD drive.
6. Select the file you want to play back, and then press the play button to start playing movies on TV via USB drive.
It's quite easy to play movies from USB on smart TV devices.
2answers
How do I use a USB to watch a movie on Toshiba TV? Or hook computer up to TV to watch it?
Hi
Most recent laptops come with a port to connect to a TV, depending upon the input ports the TV has. The two most common are VGA and HDMI, and you will need to check which of these each item has. It is then simply a case of getting the appropriate cable to connect the two together, and then on the TV select the input from the menu, and on the laptop, make sure that the external video port is active (usually a Fnct and "F" key - eg Fnct + F5 for a Toshiba Satellite Pro U200).
Hope this is helpful, if so would you please register that with Fixya
Cheers
Plasma tv how to
I suspect that with the age of the tv that it does not support videos from the USB drive. It will support update files for the tv itself which is normally something a technician would use it for.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
2answers
How do i play films on my tv using a usb port?
Is this question about watching movies made on the Meep on your TV? As I believe this has changed along the way, the OSI call center would be best able to answer that question.
Hi how do i connect my external hard drive to my ps3 and watch films
Step 1. Connect your storage device (I usually use a pen drive) to your computer
Step 2. Copy Movie to the storage device
Step 3. Eject storage device and connect to your ps3 via the USB port.
Step 4. under videos an option of your storage device should be there but do not choose X button instead press triangle for options, then select display all.
Step 6. Locate your movie and select it using X button.
Step 7. Enjoy the movie!!!! This works with MOST movie files, you may find problems watching some movie because of the way they were encoded.
Step 8. Done.
Good Luck
We were just watching a vhs movie on our tv/vcr combo unit and the picture went to fuzz however, the sound was still working. any suggestions or are we in need of a new unit.
Some VHS have a tracking button that allows the user to tune to the best signal. Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
Forgot code to unlock parental lock. Everytime I watch a p-g or r rated movie it ask for the code.
The only way I know is to reinitialize the set. You do this by pressing Menu on the remote control, the pressing the number buttons 2,2,7,0 in sequence. using the remote, press the adjust button to hi lite INITIAL, then press enter on the remote. this should put it back to out of the box settings and clearing the parental lock code.
If you have kids, I recommend they do not watch you do this.
Good Luck,
Sky Assoc
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
