Question about Hyundai T236W LCD TV
What is No CI Module ? - Hyundai T236W LCD TV
Posted by extrovert on
  • 1 more comment
  • Anonymous Mar 27, 2014
    ci modul
  • Joseph Teye
    Joseph Teye Aug 20, 2017
    Pls my 42 lg TV is giving me an error of no ci module
  • Joseph Teye
    Pls show me how to solve de no ci module problem
Rob Clayton
    New Friend:
  • 34 Answers
Hi
CI stands for common interface, there will be a slot on the side of your tv for a CI Module to be inserted, this allows you to view encrypted channels (such as ESPN) that you have to pay for using servces such as topup tv (uk).
It sounds like you have being trying to watch a encrypted channel without a CI Module inserted, this would most likely be the cause of the error message you are receiving.
Hope this helps
Posted on Mar 07, 2011
  • Robert Tingle
    Robert Tingle Jan 25, 2012
    thank you for your reply but i get this C I module inserted message on every channel i try and it comes on and goes off every 10 secs tried a new ariel and it stopped it for a while but the message as come back
Service center saudi arabia
Have anyone tried to repair this TV? Have anybody removed CI module out of it? If not, there should be some loose contact with this module connections. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 09, 2013 | LG 32LG40 32 in. LCD HDTV
Ci module
Known as a common interface module. Allows you to sign in to scrambled channels. That's th eshort explanation.....
May 28, 2013 | LG Televison & Video
No spark 1987 gmc half ton 4x4 305 ci
ignition module in the distrb or a bad module
Oct 11, 2012 | 1987 GMC G1500
My tv is LG 42LG2000. got a CI Module with tv card from local tv company to be able to watch on more than 60 channels. tv was able to detect CI module, tv card activated, but cant see where i can enter...
kindly check with the company who you got the module from..i am sure they will be able to help as they have a working knowledge of the module along with manual.good luck.
Sep 25, 2011 | LG 42LC2D 42 in. LCD HDTV
What are the ingredients of long last soft shine lipstick (ALL HEART)?
ricinus communis (castor) seed oil, euphorbia cerifera (candelilla) wax/candelilla cera/cire decandelilla, isopropyl palmitate, phenyl rimethicone, dipenaerythrityl hexahydroxystearate/hexastearate/hexasosinate, octyldodecanol, diisostearyl adipate, microcrystalline wax/cera microcristallina/cire microcristalline, ceresin, ozokerite, triticum vulgare (wheat bran) extract, olea europaea(olive) fruit extract, aloe barbadensis leaf extract, lecithin, linoleic acid, tocopheryl linoleate/oleate, octyldodecyl, myristate, cholesterol, glyceryl rosinate, ethylene/va copolymer, silica, bht [+/- mica, titanium dioxide (ci 77891), iron oxides (ci 77491) ci 77492, ci 77499), yellow 5 lake (ci 19140), red 7 lake (ci 15850), red 28 lake (ci 45410), yellow 6 lake (ci 15985), blue 1 lake (ci 42090), red 33 lake (ci 17200), carmine (ci75470), red 6 (ci 15850), bismuth oxychloride (ci 77163), red 30 lake (ci 73360, red 22 lake (ci 45380)] Personally, this does not make much sense, but I hope it helps!
Aug 27, 2011 | Clinique Long Last Soft Shine Lipstick All...
1985 dodge w350 with 360 ci engine,no spark, replaced coil, cap ,rotor, pickup unit ,ignition module,could it be ignition switch? acts like it wants to fire when i wiggle ignition with key
could be if the engine is not getting voltage from the ignition switch. take a test light and check for battery voltage at the coil and module when you turn the switch on.
Jul 17, 2011 | 1985 Dodge Ram 3500
Replaced entire ignition still no spark 88 305 ci
There are 3 possibilities. 1 the coil. 2 the ignition module. 3 the pick up coil. In my experience the ignition module is the most common cause. It is in the distributor held in with 2 screws. The coil and module can be tested at any parts house. Good Luck
May 26, 2009 | 1988 Chevrolet Suburban
Hyundai T236W LCD TV Logo
2,352 people viewed this question
Top Hyundai Televison & Video Experts
Marvin
Marvin
CoppellTVRepair.com
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
