Subtitles are always on even though settings on the disc and on the machine are off. I have set subtitles to off using the "subtitle" button on the remote. Subtitles are set to off on the disc. It doesn't matter what disc I play, subtitles are always on. How do I get rid of this?
Push the display button on remote.
If your remote has a [CC] button, push it to turn the closed captioning/ subtitles on.
If there isn't a button on the remote, look through the TV's Settings Menu ( usually under Accessibility if your TV's Menu has that tab. )
If you can't find it, you may need to get yourself a cable box etc. With the feature.
With Roku and other streaming sticks you toggle the subtitles/ captioning on and off with the [*] button.
If you want to add subtitle to online movie permanently, you can check this article.
We believe you have the Closed Caption decoder in your TV enabled. Please turn off the CC feature in the TV.
SOURCE: can´t see subtitles
Open the .srt file with wordpad and save as a .txt file. Now it will show the subtitles.
SOURCE: Subtitles are too low and can't be read...can I
Yes you can. It is called the aspect ratio. You will find it on the menu of your DVD Player. Goto the menu without a disk in the player.
You can also change the aspect ratio on some TV's to match that of the player. See your TV menu or user manual.
SOURCE: How to turn off subtitles?
Hi...
Go into the Set-up menu(using the remote)
and select OFF in the subtitle menu option
SOURCE: subtitles position are ok on pc to low on tv
The TV may have an adjustment or not to either center the picture up/down or adjust the overall height of the image--some have it and some do not.
