TMBurke and SentrySafeShop are crooks, don't place an order. Placed the order a month ago and not only have I not gotten keys, TM is not responding (sentry is his company).
Called Honeywell as they took over Sisco and they tried to find a blank for key 1443 and she said they don't even have any in the warehouse.
Looks like the only way to get it open is call a locksmith or learn how to pick locks yourself.
You can contact customer service at the Honeywell web page or directly through Sisco at the number below - They
might be able to help you recover the original combination for your
safe. They can also give you directions for your safe. Else, you might have to cut this safe open from the back or call a locksmith/safe tech. You can open this safe fairly easily with a pair of large screw drivers or pry bars or you can mail a notarized letter, requesting the combination to your safe, and include the model number and serial number to:
Sisco
2835 E. Ana Street
Compton, CA 90221
You can also fax the information to 310-638-3489.
https://www.honeywellsafes.com/
Sisco Products
2835 East Ana Street
Rancho Dominguez, CA 90221
Phone1: (800) 223-8566 Phone2: (310) 638-1182
Fax: (310) 638-6489
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working. You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
