Where can I find the code for a Directtv universal remote to work with a Phillips tv 15PF5120/28?
You can see an easy step-by-step guide to programming your remote right on your TV screen:
Press MENU on your remote control
Select program code for Directtv Universal remote. - sm_cl_blu__number3_icon.png
Select Settings
Select Remote Control
Select Program Remote and follprogram code for Directtv Universal remote. - sm_cl_blu__number1_icon.png
Make sure your TV and your receiver are both on.
Use this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV.
Slide the MODE switch on your remote control to the TV position.
Press and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons.
Using the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice.
Aim program code for Directtv Universal remote. - sm_cl_blu__number7_icon.pngress the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to progrprogram code for Directtv Universal remote. - sm_cl_blu__number8_icon.pnges, try scanning for additional codes. If one of the codes worked, proceed to the next step.
Press and hold MUTE and SELECT buttons until the green light at thprogram code for Directtv Universal remote. - sm_cl_blu__number1_icon.pngl flashes twice.
Eprogram code for Directtv Universal remote. - sm_cl_blu__number2_icon.png on the remote control. The green light should flash twice again.
Slide the MODE switch on yprogram code for Directtv Universal remote. - sm_cl_blu__number3_icon.pngIRECTV position.
Using the number buttons, enter 9-9-1. The green light on your remote should flash twice.
Aim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
SOURCE: Direct Entry Code for GE television for GE RM24911 Universal Remote
NECESITO HOJA ADJUNTA DE CODIGOS DEL RM24911 POR FAVOR
