SOURCE: i cant getta dvd picture on my kenwood kvt 719dvd...brake wire???
Did you install it, they generally sense whether youre moving by having a connection to your handbrake, if this is not connected the unit thinks youre moving but usually gives an on screen message.
To disable this you usually have to ground the brake sensor wire( connect it to the body of the vehicle)
YOU TRY THIS AT YOUR OWN RISK!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: i connect my kenwood kvt 719dvd and get a protect message
did you check continuity to ground with each speaker wire?
Have it bench tested at a local shop to eliminate or identify the unit as being at fault.
SOURCE: cracked touch screen on in dash reciever
a new face plate costs 110.95
store is called partstore.com
part # TDF-719DVD
SOURCE: Where can I get the cables and such for Kenwood KVT-719DVD
you can get on kenwoods website at http://www.partstore.com/Part/Kenwood/Kenwood/E30668005/New.aspx they are $50 the part # is also there you may search for it and see if someone has it cheaper though.
SOURCE: kenwood kvt-719dvd plays dvd but wont show picture
It is probably that the parking safety wire wasn't hooked up properly, or at all. Most in dash dvd players are equipped with a motion safety device to prohibit the driver from viewing movies and such on the monitor while the vehicle is in motion. The wire for this needs to be hooked to the parking brake light wiring. This will ensure that when the parking brake is on, the dvd can sense that the vehicle is stopped, and should therefore show the image.
