SOURCE: HP Pavilion A6130N setup error
Did you buy the computer new? It should have come with recovery disks, also called operations disks. I have had to do this with my hp pavilion lap top a few time over the past few years so that it would run faster. If the recovery disks aren't in there, call the company. They are always supposed to be included. I've always had good luck with hp, you might even go to hp's website. It's really good as well.
SOURCE: frozen screen
try to log in safe mode when the laptop is booting by pressing F8 key, you will see many option select boot in safe mode, if you can boot in safe mode then reboot normally. if the problem remains then you have to repair or reinstall your operating system.
SOURCE: Please Help with a system recovery on a HP pavilion a1253w!
The reason the cd recovery did not work is that it was made for some other HP model.
On the unit you are trying to recover, reboot the computer and press F10 . several times. You should see a recovery menu. Select the type of recovery that will format and recover the unit to OEM defaults.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: sound drivers for hp pavilion zv6000
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.hp.com/#Support
