To remove a CD from a changer that does not respond to the eject button: Look to see if there is a tiny round hole near the eject button. It will be as small or smaller than the diameter of a paperclip. If you see it then that is the CD release. You will need to find a piece of very stiff wire that fits comfortably in that hole. After you insert the wire you will feel it land against something hard in maybe about 1/2 inch. Gently press the wire and hope that there is compression of the switch which will open the CD Changer.
