Without specifics on your TV or SKY box I can only offer general information. The SKY digital satellite receiver will have a number of outputs for connection to your TV. There will be a co-axial output similar to a TV aerial connection which is for older TVs and most flat screen TVs won't be able to tune into this RF output. There will be a large black rectangular connector which is a SCART connector and this can usually be connected to most flat screen TVs with a suitable SCART lead. There should also be a small connector called a HDMI output which is now the most common way of connecting to flat screen TVs, requiring a HDMI lead. Depending on which method you use to connect to the TV, you then use the TV remote control to select the input you used, which could be listed as SCART, AV1, AV2, HDMI1, HDMI2 etc.
External Input Mode (for VCR features)
To receive the signal from an external input (decoder, satellite receiver, video camera, another VCR etc.), connect to the AV2 (DECODER) socket, and enter "002" with numerical key pads to appear "AV2" on the TV screen.If you use the AV1 (TV) socket, enter "001" with numerical key pads to appear "AV1" on the TV screen. If you use the front AUDIO/VIDEO input jacks, enter "003" with numerical key pads to appear "AV3" on the TV screen.
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
if you connect the dvd to the tv using scart socket 2 (av2) it should send a signal to the dvd, depending on the make/model of tv, you also may have to set the av2 output in the menu. Alternativly, connect the sky to the dvd input and the dvd output to the tv, this should also work.May have to watch the tv with the dvd on set to av.
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
The main aerial goes into the vcr,a fly lead then comes out of the vcr into the tv,a scart lead from av1 on the vcr into the tv.If you want to record from sky and the vcr has two scart sockets then connect a scart lead from the sky into av2 on the vcr,when you record from sky you select av2 on the vcr as your record channel
Take the main aerial into the dvd,then a flylead out of the dvd into the tv.Connect a scart lead into av1 onthe dvd and then into the tv.If you want to rec from sky connect scart lead from sky into av2 on the dvd,when you want to record select av2 on the dvd as this is the channel to record the sky on.Hope this helps
