Error code f02
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
SOURCE: They just installed a kitchenaid 36 inch KDRP467K
Hello- 'They' should have re-checked bus block connections for cord. Element won't work with one leg. If connections look good, check element connections and then power connection for element at board. If it still doesn't work, check resistance of element. Should be around 13ohms. This is the troubleshoot sequence for solution to your problem, but should be under warranty for first year. A piece of advice- avoid the 'self-clean' function. This feature is called 'self-destruct' by techs. Please acknowledge this post if helpful. Have more info if needed. Thanks- Ed
SOURCE: KitchenAid Superba Gas Range error code F3 E0 when
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened
Replace oven temperature sensor or fuse
Good luck
SOURCE: Kitchen Aid dual fuel oven, getting an error
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN
models: check door lock operation.
3. Look for a high resistance connection
or any other cause of high resistance in the oven temperature sensor circuit.
Check sensor, sensor harness and sensor harness connection at sensor and oven
control. Replace sensor if found defective.
Remember: Oven control
(ERC) measures resistance of sensor circuit, not actual oven
temperature.
SOURCE: Kitchenaid dual fuel range KDRP467KSS Oven
The thermostat in the unit has to be checked.It must be faulty or causing the problem.Also check the temperature sensor.The temperature sensor triggers the sensor to turn on and turn off.If any of the one is not functioning the oven will not maintain the temperature.
For parts diagram for disassembly.Please click the link below:---
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Range-Parts/Model-KDRP467KSS09/0593/0122007?searchedModel=KDRP467KSS&blt=
You can get
required parts from from online sites like:
--- www.repairclinic.com or from searspartsdirect online site. --------- This
should help.Thanks.Helpmech.
