SOURCE: Can you provide parts list
This is the link to parts for your model tv. I hope it helps! :)
http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=LN32A330J1D&modelid=512510
SOURCE: bought a 32" samsung lcd tv and i missin all the
Most of them use metric screw M5 or M6 0.7pitch, you should be able to get them at hardware store for about 25 cents ea.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: I am trying to find a pedestal/stand for a Samsung
If it is the same stand as a Dell W5001c. I have one brand new never used.
SOURCE: My 42 in Samsung (LN46A530) TV is flickering when I turned it on and it stays for a very long time.
A lot of the Samsung's have a common issue, there is a jumper in the power supply that needs to be removed, Contact Samsung with the model number and they can tell you if your set is one, they were fixing this issue for free.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
