1997 saturn sl did some errands, then wouldn't re-start
1997 saturn sl car started, did a few errands, returned home, about 2 hours later went out started car drove about 1/4 mile shut off car came back in 15 min. wouldn't start. could my battery be going
Re: 1997 saturn sl did some errands, then wouldn't...
If it wouldn't start, you have to see if you are missing fuel or fire. Could be a bad sensor, or a bad fuel pump, or if the security light is blinking, a problem with the security system.
Check fuel pressure at the injector rail. If good, suspect crankshaft position sensor--when it fails to start, check for sparks by pulling an ignition wire off the coils and holding it close to the coil with an insulated tool while someone cranks the engine. If no sparks, replace the sensor.
We have the same exact problem!! been happening the past year (about 5 times). Finally went all the way out friday, wasnt able to start after 2 hours, left work and went back sat and finally started after an hour. got it home and it wont start again. Why isn't there a FN recall on this problem that so many LOYAL JEEP OWNERS are having?!?!?!?
Your owners manual will tell you that the anti-theft can be turned off, but doesn't tell you how (dealer only?). If it is turning over but wont start, (trying to hit and outside temp is below 32) check the coolant temp sensor. Saturns notorious for cracked sensor sending false info to computer thus flooding engine.
Most likely your Generator has failed or you have a battery connection isssue.But based on the info you provided it sounds like the generator.You need to remove it or take the car somewhere & have the charging system tested.hope this helps
i would check the starter it sounds like the started is getting hot and the solenoid on the starter is losing the connections inside and when it cools off it is making contact again
it turned over, but wouldn't start, cranked for a few times
Wouldn't turn over, or wouldn't start?
