Programing
Here is your downloadable owners manual with complete instructions.
Radio Shack 20 405 User Manual
SOURCE: Owner's/Instruction Manual
Hi SDGirl - This is a slightly older model and there's not much out there. You won't find one at Tandy or Radio Shack Sites. I'll give you a link where you can find it ( sort of) in sections. I believe it will tell you everything you need to know. If I were you I'd probably copy and paste each section into Word or something so you'll have it all in one place. This is about the best out there. If this solves your problem PLEASE rate this as fixed. ( I looked alot for you). If you need more help just add a comment and I'll be happy to assist you further. If this doesn't solve your problem let me know before you rate and I'll try for something better. Thanks.
http://support.radioshack.com/support_electronics/36547.htm
Jeff
SOURCE: need to know how to program a radio shack pro-94 handheld scanner
press the "prog" key followed by the "Trunk" key then the number "1" key.
Press the "down arrow" key until you see the initials Ed on the screen
Press the "E" key.
Enter the frequencies (including the decimals)
you must press the E key and the Prog key after each frequency, after you finish entering your frequencies, press the scan key.
If you need to clear your scanner, turn it off, press and hold down the number 2 and number 9 keys, while holding them down turn the scanner back on, "clear" should start flashing on the screen, once "clear" stops flashing you can enter the frequencies.
SOURCE: program scanner
Heads up that in some countries / States this can carry severe penalty.
I cannot give any direct information and it up to you to make sure you apply to the laws of your state etc
A good source of information are the two sites below
Frequencies
Scanner software
With any luck you will also find either the manual or a link to it there as well as quite a lot of other useful information that would give you guidance as to the legality
SOURCE: how to program radio shack pro 82 scanner
is it a digital scanner? You know that everyone has gone digital there fore making that kind of scanner outdated and if you are trying to listen to police u wont pick anything up. I was told that some raido shacks will re program it for you.
