20 Most Recent Radio Shack Pro-84 Handheld Scanner Questions & Answers
2answers
Pro 84 locked up says
Your scanner should only enter the WIRED mode if you have a clone cable plugged into it. The only way to clear the problem is to RESET the scanner. Unfortunately this procedure will also erase all the frequencies that are programmed into the scanner. RESET is covered on page 54 of the scanner manual -- if you don't have yours you can download and print a copy here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000516_PM_EN.pdf
Bill B.
Listening in since the 60's
7/3/2015 3:39:49 PM • Radio Shack... • Answered on Jul 03, 2015
How do I program my Pro 84 scanner
5/18/2015 7:48:09 PM • Radio Shack... • Answered on May 18, 2015
How come my pro-84 scanner wouldn't hold the mrn frequency last weekend in richmond. Kept getting an error message. pressed hold, entered the station 454.000 and then hold again and kept getting err
454.000 is not a station, but a frequency. it is 454 Mhz. or 454.000 Khz. If no station is transmitting on that frequency, the scanner only will produce a hiss. Check the manual, to see how you can put in a frequency, just to monitor. Put the sq, so you just don't hear the noise and wait till any transmitter will use that frequency.
5/23/2014 8:54:34 PM • Radio Shack... • Answered on May 23, 2014
Reseting or clearing a radio shack pro 60 scsnner
turn scanner off, then press and hold down both the 2 and 9 keys and turn scanner on.
3/29/2014 10:56:29 PM • Radio Shack... • Answered on Mar 29, 2014
2answers
I have broken the six
Any Radio Shack store should be able to order one for you Before you go that route though, check eBay. The battery holders come in several shapes, but you might find one that will work for you - at a bargain price.
Bill B.
Listening in professionally since the 60's
8/6/2013 2:15:35 AM • Radio Shack... • Answered on Aug 06, 2013
3answers
PGM WIRED
pgm wired how do i fix this?
8/6/2013 1:31:45 AM • Radio Shack... • Answered on Aug 06, 2013
0answers
Pro 84 scanner what kind of batteries does it use
It uses two AA batteries.
4/24/2012 5:12:57 PM • Radio Shack... • Answered on Apr 24, 2012
My Radioshack handheld scanner is stuck on Weather ATT 162.4000 and will not do anything. It isn't even giving the weather.
press reset button but doing this you will lose any saved memories and frequencies
11/21/2011 1:30:48 AM • Radio Shack... • Answered on Nov 21, 2011
It would go in and
hello it sounds like the priority button is programmed to that perticular frequency solution go to the frequncy manuly press and hold priority button untill it disapears fro the screen
3/30/2011 11:40:31 PM • Radio Shack... • Answered on Mar 30, 2011
2answers
Need SUFFOLK COUNTY P.D. RADIO
Hello kevin,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
Here is a link where you can get the frequency's for your state. www.RadioReference.com .
Hope this was helpful. Your Comments and Testimony's are always welcome here.
Thanks for Choosing FixYa today and in the future.
John
3/20/2011 10:16:40 PM • Radio Shack... • Answered on Mar 20, 2011
I have a pro 84
Sorry, but the NASCAR label on these scanners is little more than a scam. There are no special features that make race scanning easier or organized -- they just cover the frequency range that cars and pit crews operate on.
Bill B.
3/16/2011 7:30:59 PM • Radio Shack... • Answered on Mar 16, 2011
I DON'T HAVE A MANUAL
To clear (RESET) the scanner:
- Power it OFF
- Press and hold the 2, 9, and HOLD keys and power the scanner ON
You can download and print the factory manual for your scanner, at no cost, here:
Bill B.
3/6/2011 2:31:26 PM • Radio Shack... • Answered on Mar 06, 2011
Need a user manual
You can download and print your scanner manual, at no cost, here:
Bill B.
2/27/2011 2:58:16 PM • Radio Shack... • Answered on Feb 27, 2011
How to program
The best programming instructions for your scanner are in the factory manual that you can download and print, at no cost, here:
You can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, by visiting:
Bill B.
2/25/2011 5:33:45 AM • Radio Shack... • Answered on Feb 25, 2011
Pro 84 scanner how to search for frequencys
You can download a copy of the user's manual here if you need it. It doesn't look like you can set your own scan range, but you can have the scanner search by pre-defined service. Here's what the manual says about searching:
service search
You can search for weather, ham, marine, aircraft, or
police (fire/emergency) transmissions without
knowing the specific frequencies used in your area.
The scanner is preprogrammed with all the
frequencies allocated to these services. To use this
feature, press FUNC + SVC. SRCH appears and the
scanner searches starting with the weather service
bank. To select a different service bank, repeatedly
press FUNC + SVC. Service mode appears on the
display.
When the scanner stops on a transmission, quickly
press HOLD to stop searching and listen to the
transmission. HOLD appears. In this mode, you can
press FUNC + ^ or FUNC + v to step through
the frequencies.
To release the hold and continue searching, press
HOLD. Or, if you did not press HOLD, simply press
FUNC + ^ or FUNC + v to continue searching.
It goes on to explain how to store frequencies as you find them while searching.
2/24/2011 5:40:34 PM • Radio Shack... • Answered on Feb 24, 2011
I cant find an operators
You can download and print your manual, at no cost, here:
Bill B.
2/24/2011 2:21:52 PM • Radio Shack... • Answered on Feb 24, 2011
I don't know how to
You can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, here:
Bill B.
2/19/2011 2:39:39 PM • Radio Shack... • Answered on Feb 19, 2011
Looking for a 20-047 USB cable or a 20-289 serial
Go to the links below to get the cable.
http://www.radioreference.com/apps/classifieds/showproduct.php/product/2247
http://www.radioshack.com/product/index.jsp?productId=4233363
You need either the Radio Shack PC interface cable 20-047 or the GRECOM USB cable. Both are, unfortunately, out of production and not available through any outlet that I could find. You might want to check with Radio Shack stores in your area, though, as one or more of them might still have the cable in stock. Another possible source is the PRO-97 owners group on Yahoo.com.
1/30/2011 2:31:27 AM • Radio Shack... • Answered on Jan 30, 2011
Radio Shack Pro-84 Handheld Scanner Logo
58 questions posted
Top Radio Shack Radio Communications Experts
Robert McClure
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Radio Shack Radio Communications
Most Popular Question
broken six
  • Radio Communications
