SOURCE: NO SOUND FROM MY RIGHT SPEAKER Z4
Open
Startmenu->control panel->sound and audio devices
Do you see a window which says "no audio devices installed" ?
This should fix the problem.
Otherwise I would suggest some more.
SOURCE: Logitech Z4 sound from one side only
Reconnect all the wirings in your speaker set. Be sure you connect all the cords properly.
SOURCE: I have some logitech Z4 computer speakers
If your TV has a headphone socket, then plug the speakers into there, then (you have to do this for some TVs, but not others), go into the set-up menu and turn the headphone volume to 70%. Switch on the Z4 and sound should come out, assuming all connections are correct.
SOURCE: buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
