ITec Portable Power Station wJumpstarter and 400w Inverter Logo
A
Anonymous Posted on May 28, 2014
I've had for 14 months it just stopped workingAt TV 20had for 14 monthsAre used it twicec tc t2031 problem.2
Jensen Beach Speed Shop
Level 3:
Master:
  • Master 710 Answers
  • Posted on Sep 02, 2014
Master
Level 3:
Master:
Answers
710
Questions
Helped
141127
Points
7635
It has likely failed and requires repair or replacement. Check to see if the battery is good.
Problem rolling bars
It should be a main power regulator baord fault. Contact any service technician.
I'm getting really low mpg on my Scion tC 2006
clogged air filter, proper air in tires, wrong octain for car? who knows, it could be all of this
It has power but no display
If its a 14 inch it may not be cost effect to fix----If no sound no picture no brightness look first for the fuse the set will have.
Other possible reasons include a bad solder connection or connections on the single board this set should use.
Let me know if you need more help or advice
Panasonic Viera TC-P46S30 14 blinks
14 blinks won't occur to Panasonic Plamas. Just count the number of blinks once more.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Blinking codes for Panasonic Plasmas are described in detail. Search the site with patience. You will get a solution.
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
4helpful
2answers
Mistakely locked my TV(4 system CATV HYPER-BAND TC-2101T)
my TV locked, but the password had not been activated. what can i do
1helpful
Two lines appearing and moving up and down on my Pana 14"color tv
Hello, This is called 60cycle hum and it is caused by the 60Hz signal of the power supply "leaking" into the video circuitry. It is caused by a faulty filter capacitor. and can be seen by using an oscilloscope. I would suggest that you take the TV to a qualified TV technician for servicing, because this type of repair is not for the do it yourself person. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
1helpful
2answers
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Top i-Tec Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an i-Tec Vehicle Part and Accessory Expert? Answer questions, earn points and help others
