Question about Vehicle Parts & Accessories
Trying to find the radio code to a Hyundai getz 2 2005---kmhbt31ar5vio3845
Posted by lycos2 on
Anonymous
    New Friend:
Have just heard you only need the last four (4) numbers.
but you must add 1212 to the numbers, if your first number is 3 add 1 to make 4, if the second number is 6 add 2 to make 8, third number add 1 again and so on
Posted on May 12, 2010
  • 3 more comments
  • patglover Jan 28, 2011
    Just did this - it worked but it can be a bit trickier than you think if you have an 8 or 9 in your code.
    -so get your radio out- using the metal ruler technique, on the end of the huge barcode is an eight digit number e.g mine is (01) 15 digits (21) 05062479.
    Adding the 1212 to the last 4 digits gave me 3681- this totally didnt work.
    The trick is to add it in reverse and carry the remainder to the left so 9 2 =11, (last digit =1), 7 1 1(carried over from last addition) =9, 4 2= 6, 2 1=3, so my code in the correct order now is 3691.
    Now you just enter it in- make sure its saying CODE first - otherwise pull out your radio fuses for a second and then put them back in and try it again.
    you have 3 chances to get it right each time(then redo the fuses again)
    press "1" button repeatedly until it reads your first digit e.g.3, then 2 button unitl it reaches the right number for you, same with 3rd and 4th digit then finally press button '5' as your enter key - all done- sweet as.
    Hope this helps- it took me almost a fortnight of no radio to go into hyundai and ask them-as i was told it was going to cost $60 but in the end the guy just helped me out with my code and i did it myself.
  • cooltony2001 Feb 17, 2011
    Thanks a lot Dnaman. i have add the 1212 in that code but with patglovers technique and it works. one again thanks guys.
  • godmus Apr 05, 2011
    Hi my father just lost the code of his Hyundai Getz model 2007, and I contact the Hyundai dealer and from there side they told me that can't help us to give us the code.
    I tried to add the 1212 to the serial Number that it is MT04070625 and the answer came 1837. Then I tried to enter this code 1837 but it doesn't worked.
    So I am thinking that I done the wrong calculation. If you think that I do it in the wrong way, can you please help me and tell me what should be the code answer please.
    The serial number is MT04070625.
    If you can please send me the answer on my email: [email protected],com
    So thank you in advance for your very kind attention and hope to listen from you soon
  • Tania Jan 12, 2013
    When using this 1212 trick do you use the last 4 digits of the cars VIN number or the last 4 digits of the stereos serial number?
    Does the 1212 method work in 2008 Hyundai getz's? and do you use the last 4 digits of the cars VIN number or the stereos serial number?
Anonymous
    New Friend:
Remove your stereo by sliding a metal ruler down each side. Then on top you'll see a barcode. The las eight numbers is your serial no. Every second number of these eight numbers is your security code. example. last eight numbers are :13246590. Your security code would be 3450
Posted on Jan 28, 2010
Anonymous
    New Friend:
A big thanks to Langly his solution worked and we saved $55, cheeky sods wanting to charge that amount for a 2 min job.
Posted on May 25, 2010
Mark Mead
    New Friend:
I have just Re coded 2x 2010 Getz's using 1212 system, on last 4 serial No/ Digits.
Note If Your Digit + 2 rises Above 10 you must carry the base 10 to the Next Digit (Left) as with any Maths Equation.
ie 9+2=11 Carry The 10
ie 1934 +1212= 3146
I have just Realised if you Use A Calculator! it Gives you Your Pin Number!
Easy or What//
Car-market Rotorua
Posted on May 24, 2015
  • glenn
    glenn Nov 01, 2015
    mate you are a f*#[email protected] legend-thanx heaps ,no other forum explained the 9 carry over.
damiano
Hi i have a Hyundai getz 2010 model which is the 1212 system doesn't work. any other suggestions ?
Posted on Dec 01, 2013
jaguar33
    New Friend:
  • 3 Answers
Be aware guys that this does not work for all Hyundais - even though Hyundai say it should. The PINCODE given in the documents with the new Hyundai is based on the 1212 technique as described here. However for some it does not work - think about it. It means the original pincode Hyundai supply is not even the correct one for the radio. Hyundai do NOT test the pincode they simply use the 1212 technique and print that on the code card.
Hyundai Customer Service will then claim that the Head Unit is faulty. Believe me, this is NOT the case. Hyundai never supplied the correct pincode in the first place.
Posted on Aug 17, 2011
There is a 1CDE code on my Hyundai Getz radio
You may need to go to a Hyundai dealer on this to resolve your issue.
Dec 27, 2017 | Hyundai Cars & Trucks
What is the radio code for a 2006 HyundI Getz
Every radio has its own code. You will need to contact your local Hyundai service department for further assistance.
Dec 20, 2017 | Cars & Trucks
How do i retrieve my puk number of my car radio hyundai getz 2009 model
puk codes only refer to mobile (cell ) phones
you want the radio code for the wireless
Mar 31, 2017 | Hyundai Cars & Trucks
How do I find the radio code for a Hyundai getz 2008 1.6
from your dealer need to notify them with vin and proof of ownership
Sep 07, 2016 | 2008 Hyundai Getz 1.6
Hyundai getz radio security code
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Hyundai service centre and get them to enter this code for you.
May 09, 2013 | Audio Players & Recorders
Hyundai getz 2007 car audio code
try another hyundai dealer in your area. Someone should have it on record somewhere. Tell them to stop being lazy..
May 31, 2010 | 2007 Hyundai Accent GS Hatchback
Vehicle Parts & Accessories Logo
12,110 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
