I think you might have a separate flasher for the turn signals under the dash. The turn and hazard flasher would look alike. Turn you hazards on and find the flasher for it under the dash. You will probably be able to feel it working and hear it clicking. The other flasher under the dash is for the turn signals. Try replacing that one. I think it was in later years they began to combine the two into a single composite flasher.
need to replace signal flasher unit..cheap fix.located usually under steering colum or around fuse box. If you dont know what it looks like ,go to parts store and see what it looks like. usually small and round..it will be easier to locate.if no fix then you will need turn switch. sometimes you can tap the flasher unit and it may work a couple of times it
sounds like the awitch is bad ....first check connection in the steering colume....where the switch plugs in ....the turn signal switches themselfs do go bad
likely a multifunction switch problem but first try to replace the 4 way flasher with the signal flasher located under the steering colum fallow the clicking to locat flasher
Does you emergency flashers work? If so the turn signal unit in the colum is bad. If not you have lost the hot wire going ti the turn and emer.light circuit. Hope this helps
Which switches on the steering column? Hope the switches were replaced with the battery disconnected. That alone could be the problem. Who did the switch replacement? If it was a business, you need to return to them and demand they do the work properly.
The turn signals and the emergency flasher are controled by one electronic flasher unit at the far left under the dash on the driver's side. It has a three wire connector and is attached to a mounting bracket with one screw.
