SOURCE: pentair intelliflo variable speed pumps
Extensive information available is available from Pentair. Owners manual http://www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf Quick start guide http://www.pentairpool.com/pdfs/intelliflovsQSG.pdf
SOURCE: We lost our password for
On the normal vs-3050, you need to reset the whole unit. You do this by holding all 4 speed buttons for 30 seconds. After thi, shut off the power at the breaker. let sit for 2 minutes. Restore power and all setting are reset. I cant find any information about the SVRS model, but it should work the same way.
SOURCE: SWAPPING OUT A HARD DRIVE
If I can assume you are swapping out the Control module on an intelliflo, there are no directions needed. Just remove the 4 screws from the top. Then it is loose and you can dissconnect the wiring plug. Reverse to replace the new one. Very simple. But if you need a manual:
SOURCE: Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
The LCD on the intelligible model is poorly water proofed. In most cases it needs to be replaced along with the entire unit costing about $700. There is a YouTube video where they opened up the LCD and clean off the electrical board & contacts with alcohol on Q-tips but I have never tried it so I can speak for It.
