SOURCE: pentair intelliflo variable speed pumps
Extensive information available is available from Pentair. Owners manual http://www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf Quick start guide http://www.pentairpool.com/pdfs/intelliflovsQSG.pdf
SOURCE: Have Pentair VS 3050 Intelliflo
If the supply cable it getting hot then it sounds like its not rated high enough for the current and could have burnt out.
What size and type of protection have you got on the circuit thats supplying the pump and do you know the cable size (CSA - Cross Section Area - 1mmSQ. 1.5mmSQ etc) and what is the length of the supply cable.
Do you have a multimeter or continuity meter to carry out some test?
SOURCE: Problem with IntelliFlo VS-3050. The
Thank youfor posting your question here on Fixya.com.
I recommend you call the Pentair technical support at800-693-0971 and they should be able to help you figure this issue out. I hopethis helps.
Ifthis answer does not resolve your issue, please comment with additional informationbefore rating the answer. Positive feedback is especially appreciated once yourproblem is solved! Thank you
SOURCE: Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
