Hi, I replaced the panel with a new one but after following the re-programing steps the oven wont work. Its goes to preheat and 15 seconds later error 160 strat beeping. I already know that the code 160 is related to replacing the panel but nobody can tell me how to void and overwrite the error 160 after replacing the panel.
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven
ignitors can glow and allow enough current through to open the oven gas
valve but just not produce enough heat to ignite the gas immediately
(see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
SOURCE: bosch oven model HGS3052UC doesnt close tightly,
yesthis is a common problem with this brand. 2 things can be done. 1. replace the hinges left and right or add 3 washers on both sides of the hinge to bring the door hinges closer.Im a old bosch tech and I told them this was a issue.
