Has happened before. repair suggested there was a loose connector. they recrimped. now same problem
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
SOURCE: I have a Go Go scooter that is an older model. It
Hi, That sounds like the speed pot is faulty,
When going along push the lever in the upwards direction as well as forward , does it speed up ? does it response ? if so then that's the problem.
There could be a issue with the metal key making a good contact when inserted.
Regards
GeWiz.
SOURCE: have 2 new batteries in scooter but it is very
mcdevito75 here, Sounds like the motor or clutch in the motor is giveing out, check with any Medical supply store in your area for repairs.
