Model # JWB-87 Serial #6787
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
SOURCE: whirlpool jacuzzi tub is not turning on when power
there might be a fuse at the pump that has blown
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
SOURCE: have a whirlpool cadet jacuzzi tub and black slime
You have a bacteria problem. You will need a cleaner to run through your system. some names to search for ... system flush, Jet Clean, Jet Fresh
Once you run the cleaner through your tub that will eliminate the sludge you are getting
