20 Most Recent Jacuzzi - Bathtub - Alcove - Navona - R105917 Questions & Answers
Did you see any mold? Did you see any areas that are wet? TOXIC is a term that is used to describe something that is poisonous. I think you mean noxious which means unpleasant and possibly harmful. The smell of sewage would be classified as this.
Jacuzzi -... | Answered on Jan 28, 2019
Is it greasy, oily spider web type junk? Coming through the pipes, new construction or new tub? Could be from the pump, not that it is leaking oil but it has oil in it from the manufacture of it. I would call the jacuzzi people and tell them what you have and that your kids play in the tub and drink the stuff, ought to get them to move on that one. Ask them if they know what it is and what to do about it? Hope this helps.
Jacuzzi -... | Answered on Mar 28, 2017
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Jacuzzi -... | Answered on May 25, 2014
In order to properly seal the jet in place with silicone you must remove the wall fitting from the inside of the tub. The wall fitting is threaded into the jet body from the inside of the tub.
Once the wall fitting has been removed you can put a small bead of silicone around the underside of the flange and thread it back into the jet body. Clean up the excess silicone after it squishes out with DeNatured Alcohol.
If you plan on just putting a bead of silicone around the outside edge of the jet body behind the tub, do not waste the silicone or your time as it will not solve the leak in the tub.
US Parts Center
Jacuzzi -... | Answered on Dec 05, 2013
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Jacuzzi -... | Answered on Oct 18, 2012
there are not products currently for sale to do what you are asking for.
Jacuzzi -... | Answered on Feb 17, 2011
Currently there is not a solution for capping off the jets in a jetted tub.
Jacuzzi -... | Answered on Feb 08, 2011
currently there are no solutions out there for plugging off the jets in a whirlpool tub.
You should be able to remove the access panel and just disconnect, and cap the hose that is connected to the pump for the jets and then cap the pump nipple, where the hose connects.
This would likely be easier than trying to locate multiple caps to plug the jet holes in the tub.
I hope this helps you.
Jacuzzi -... | Answered on Feb 02, 2011
that is because your system most likely has a 10 minute timer on it. preset so that the pump doesn't stay on for long periods of time.
Jacuzzi -... | Answered on Feb 01, 2011
Obviously a circuit overload, or short. Was it working ok, before, and have you by chance added anything to the circuit that supplies power to the tub?
Jacuzzi -... | Answered on Jan 12, 2011
that is a display error showing there is not enough water flow to activate the heater. Take the filter out of your tub and see if the error goes away. if it does then you need a clean filter. if it does not go away then you have probably have a bad pressure switch.
Jacuzzi -... | Answered on Sep 06, 2010
buzzing sound on a motor means it has almost burned out. you will need to replace the pump.
Check for any GFIC receptacles in line some where tripped out. Check breaker and make sure it's working properly.
Jacuzzi -... | Answered on Jun 10, 2010
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
Popular Tags
49 questions posted
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
inground pool seems leak
  • Home
