Question about JACUZZI Fresco LH Whirlpool Bath Tub WHITE BM95959
What plumbing material do I need
Posted by Moses Carter on
US Parts Center
  • Jacuzzi Master
  • 719 Answers
What are you trying to do with this tub?
Posted on Dec 05, 2013
4 Related Answers
Anonymous
  • 152 Answers
SOURCE: Bath tub spa will not shut off
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Posted on Feb 22, 2009
Alan
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
Anonymous
  • 120 Answers
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Posted on Jan 20, 2010
joeguest2
Joe2
  • 2080 Answers
SOURCE: i have a regular size bath tub with a jacuzzi with
First of all make sure you have the tub filled with water to a level above the jet inlets. They normally have a sensor to prevent the tub from starting dry.
Next, check and reset any GFCI electrical receptacles that might be on the same circuit as the tub. They are the wall receptacles that have the 2 little buttons in the middle. Look in the bathroon, adjacent bedroom, closets etc.
The only other thing you can really check on your own is the air tube leading to that metal switch on your tub. The switch is not electrical for safety, it is a little air pumper with a plastic hose attached to it leading to an air powered actuator on the pump. Sometimes the hose dries up / comes loose / falls off. Check if there is an access panel on the tub where you can look inside and see if the plastic hose is still attached at both ends. You might even be able to unscrew the metal switch cover and lift it up and see from there. Otherwise try fpumping the metal switch (firm repeated pushing) to see if that will activate the pump. If that does the trick then it is probably just a loose connection / leak on the air hose such that it is not quite airtight.
Good luck and please comment back if this was at all helpful or if you need further assistance.
Thanks.
Joe.
Posted on Feb 13, 2011
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
Need to purchase 2 front panels [white] for Luxura 530 jacuzzi whirlpool bath model N795 also, called skirts
Bath Panels can be very difficult to locate. I would check with your local Jacuzzi Showroom first.
If they are unable to locate the panels you need or they are no longer made then you should head over to Lowes or Home Depot to get a generic panel from one of them and you may need both panels replaced so they match.
rod
US parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 16, 2013 | Jacuzzi Home
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
Back jet near front panels leaks, what part do i
You may not need to replace any parts. If it is leaking around the seal (which I have had happen on occassion), a high quality silicone adhesive should be applied. However, it is best to unscrew the jet at the connection so as to get good coverage. Just applying the adhesive around the connection without getting it between the unfinished portion of your tub, is just asking for future problems.
Nov 17, 2009 | Jacuzzi Cetra Whirlpool Bath LH WHITE...
How to wire a jacuzzi whirlpool tub? What to use for wiring, timer etc?
get an electrician. you need to follow the code for the size of wire to use based on number of amps of the motor and how far away the pump is from the power outlet.
Sep 29, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Overheating problem
It sounds like the problem is in the main control box. Since the tub shuts down after reaching 110 degrees, the high temp sensor is doing its job. This sounds like a job for a qualified professional. Do get a price for the service call as they are usually expensive. Circuit boards start at 200.00 and go up.
Sep 15, 2009 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
No access panel and need to reconnect the vacuum hose
The trip lever is an over flow for the tub to prevent you from over filling the tub capasity and flooding your home.
Mark
Dec 24, 2008 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
JACUZZI Fresco LH Whirlpool Bath Tub WHITE BM95959 Logo
113 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
