SOURCE: my kenmore front load tumble action washer will
If the brain senses water in the floor then the machine will shut down. You have to remove the water, and find the leak. The moister sensor keeps your home from flooding should the tub get a terrible leak from a ruptured hose etc. You mission should you decide to accept it Mr phelps is to locate said leak and eliminate it before you have nasty clothes up the kazoo. This message will self destruct in five seconds Good luck Jim. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
SOURCE: Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
SOURCE: Hello. I have a Super Capacity Quiet Tumble Easy
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
SOURCE: I need a manual for a Kenmore Super Capacity 3.5
See the following Sears site:
http://www.managemyhome.com/
Click on the Manuals tab, enter your model number and you should be able to get a PDF version of the manual.
Testimonial: "Thanks! That worked great. But now I figured out by reading the Owners's Manual what I really need is the Operating Instructions card."
