SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
SOURCE: Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
SOURCE: Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
i had this issue on my Hotpoint HSS25GFP and it was a piece of ice hitting some fan blades in that area behind the icemaker.
SOURCE: My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
