Ideally, you'll get a high-powered bulk tape eraser that is designed for video tapes and will work perfectly for audio tapes, as well. An audio tape eraser will work to a point, but usually won't blank them out completely since it doesn't put out a strong enough electromagnetic field to erase videotapes completely. I personally own an old Radio Shack high powered eraser and it works to erase both video and audio, as well as a demagnetizer for old color tv screens (when used at a distance...a bit too strong up close), and demagnetizing screwdrivers (the ones I don't want magnetized, that is). Hope that helps.
I have the same problem. I just bought a sony handyman and tried to play my old tapes and nothing, not even sound. But I just recorded something using an old tape and it records and I can play that back. I'm thinking maybe over time, somehow all the data on there got erased. Which is really a bummer.
If you were using an old tape in camera then its quite possible that video heads can get clogged/ dirty. Dusty environment can also be cause of dirty heads.
Video head was dirty / clogged due to old tapes usage so it did not recorded any signal on tape and now it requires cleaning with good quality head cleaning tape to record and playback properly.
Since the JVC GR-D740EK is a european miniDV camcorder with no embedded memory nor memory card slot, I would assume that your talking about erasing or recording over your miniDV tapes. You can simply do so by sliding the the erase protection tab on your miniDV tape towards "record" and you can begin to record you movies. Prerecorded tapes cannot be deleted and used as "new" or bare (having no recording on it).
Yeah, a strong magnatic field can erase whole tape at once. You can try it by using Deggausing Coil at TV repair shops, though i have not tried it yet.
