Yamaha RX-V750 wont power up
Check the fuse. You might have had a power surge which blew a fuse. If not, check the fuse for the socket. Reset the fuses for that socket. If it still doesn't work, it sounds like the internal boards got fried, or the power supply got fried. The power supply is replaceable, but we don't know if it is the power supply. To check, connect a voltage meter to the power supply.
Something like this happened to me. I found a new kenwood stereo next to the dumpsters, stickers and all still on it, plugged it in, it worked, shut it off to plug in a speaker, didn't turn back on, months later after leaving it plugged in, turned on, I used it, then shut it off for the night, in the morning the standby light was still on, tried turning it on, but it wouldn't for some reason, unplugged it, then the light wouldn't come on, it was once again sitting on a shelf as a paperweight, one day it randomly came on again, and now it 100% works, and I use it as an amp for my RE audio subwoofer, and its worked great since! The reason this kinda applies to you is because its kinda simmilar what happened to you. Just leave it plugged in, and maybe sometime you will walk by it noticing it works.
