DE608m oven cooked a meal then the power went out to the oven, fuse not blown at the power board
SOURCE: Cooker power has gone.
has it come back on? if not it may be a connection going into the back of the cooker or if it has come back on it may be an overheat stat kicking in -check the blower (cooling) fan is ok.
SOURCE: stove has no power ( kenmore )
Sounds like it could be one of a few things:
The Fuse - Check this first. Have you a electrical safety cut-off switch box? Check if the kitchen appliances switch has tripped.
The heater element - you'll be able to tell if there are any bulges or blows on the element.
The transformer - most appliances have a built-in power transformer. Yours may have overloaded.
The PCB - This would be just plain bad. It's the clever chip that controls everything and it's expensive to replace.
If you have a phone number on the appliance for a 5-year free parts warranty; I would take it out. Then you only pay about £90 for the service.
SOURCE: oven not heating
Hi
The problem will be the fan element. remove back panel inside oven from there you will see the element just repalce and you will be back up and running. hope this helps you
regards dan
