I have a kitchen aid model # kebs179bss oven and I was cooking something in oven and power went out and after power came back on the oven has not I check breakers it OK does control panel have a fuse and how much does it cost to replace
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Posted on Feb 02, 2017
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
SOURCE: Oven burners won't shut off
Bat, your model number is right on accurate. Here's the scoop... the F3-E2 means the temp sensor inside the oven cavity needs replacing, but I doubt that your problem is the sensor. The problem is your "microcomputer". I call it an ERC for short. There are 3 separate circuits on your ERC; low voltage for your keypad, medium voltage for the mechanical relays and high voltage for you elements. When you program a cook time/temperature, the ERC translates this into medium voltage and activates the proper relay on the ERC (i.e... "bake", "bake w/ convection", etc...) to send high voltage to the proper component. All of that to say this, the relay on the board that activates the bake element is "welded" shut. When powered off, the relay won't open up! This will result in run-away temps. I've seen this before on Whirlpools. The ERC will have to be replaced, the part number is #8302994 and lists for ~$180.00 at your local appliance parts store. If you need assistance with the replacement procedure, post back. If you decide to get in there without posting back, DISCONNECT POWER AT THE BREAKER PRIOR TO ANY SERVICE.
Posted on Aug 15, 2007
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
SOURCE: Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
Posted on May 24, 2009
SOURCE: Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Posted on Jun 13, 2009
