Dell W4201C 42 in. Plasma HDTV Logo
Stephen Gentry Posted on Feb 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to repair a broken screen on a DELL W4201C 42" High Definition HD Plasma TV and I live in Columbus ohio?
Level 3:
Top Expert:
  • Dell Master 76,851 Answers
  • Posted on Feb 28, 2014
Dell Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008662
Points
237762
Please do not waste time and money. Buy an other TV. Gopakumar Gopalan Google
Testimonial: "Thanks!"
5 Related Answers
Anonymous
  • 3940 Answers
  • Posted on Jun 13, 2008
SOURCE: Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Anonymous
  • Posted on Jan 21, 2009
SOURCE: 42 in dell plasma, no picture, sound works fine
tellme the solucion charge me
Anonymous
  • 3 Answers
SOURCE: dell w4201c hdtv plasma tv BLACK SCREEN, LOGO FADES OUT, SOUND REMIANS, HELPPPPPPP
the problem was the y-sus board, i had a local tv repair shop diagnos that much for me. although, he couldn't fix it i did some research and found a company in california, itritek.com, who could. you send him the y-sus board and the two buffer boards and he not only repairs them but he upgrades them. apparently the y-sus board gets too much heat and eventually goes out, sometimes the buffer boards are affected too. itritek.com replaces the components on the y-sus board with better parts which are more heat resistent. i believe this will help you with your problem. let me know...good luck.
Anonymous
  • 90 Answers
  • Posted on Mar 24, 2009
SOURCE: help
the problem can be traced from the power bd. you will need a digital volt meter. There are settings located on a sticker located on the upper right corner Va,Vset,Ve, Vset etc..... each one has a DC voltage. compare the voltages to trace the source. My suggestion from experience is the Y Main upper or lower buffer which ever has a brn mark located on the metal of the panel. Google a local dell dealorship or a repair company in ur local area, and get serviced.
Anonymous
  • 51 Answers
  • Posted on Aug 28, 2009
SOURCE: 42" Dell plasma TV
Y SUS and Buffers are usual culprit.
You can get it from guy at
[email protected]
He has everything for Dell TVs
2helpful
2answers
DELL PLASMA
Most cases the Y-SUS, Y upper buffer, and Y lower buffer is the problem. The replace the 3 boards are located on the left side of the chassis when you open up the TV. 90% of the time this will solve the problem.
Look for burn marks on the upper and lower buffer boards (mostly around the chips with the heatsinks on them).
Black line in the middle of screen
It is possible the connector to from the address board to the screen may be need to be cleaned & re-seated, but almost 99% of the time this fault is a problem within the plasma screen & the only solution is for a replacement screen.
W4201C HD IS SHUTTING OFF BY ITSELF
From the web site that does sell boards, It doesn't seem to have the same parts.
Here's your TV parts:
http://www.shopjimmy.com/catalogsearch/result/?q=w4201c
And here's the W4200HD parts:
http://www.shopjimmy.com/catalogsearch/result/?q=w4200hd
I hope I answered you question.
No picture or sound on Dell w4201c plasma tv
hi its right time for u to go for a replacement of new plasma screen... its available in dell shops... bcoz repairing might cost u heavier...
thank u rate me
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Dell w4201c hdtv plasma tv BLACK SCREEN, LOGO FADES OUT, SOUND REMIANS, HELPPPPPPP
1helpful
2answers
DELL 42" High Definition HD Plasma TV wi4201c hd
There are no real user serviceable parts in that TV. You could take it to a Repair shop and get an estimate for repair, but it is likely that you might end up getting a replacement for a lower cost. Most TV shops have a checkout fee ($25 to $75) generally. If the screen itself is not bad, then the repair cost shouldn't be too high (Logic board or such)
Top Dell Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Paul Bade
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
