Car Audio & Video Logo
A
Anonymous Posted on Feb 17, 2014
I NEED THE WIRE HARNESS COLOR CODE FOR A FUJITSU TEN EQUALIZER
Is there anyone who can answer a question re color codes for matching wires from harness to stereo i have a pioneer stereo and and need to install it in a honda civic need to match its wire colors to...
hoy cr*p. Thats a big question. I'm used to the simple hook up of red = hot wire, black equal ground wire, and white usually goes to the speakers. MOST electronic equipment use red as the "hot wire"...or the wire that is the main electrical wire. If your colors dont match, you might talk to a shop that specializes in installing car stereos. Good luck. thats how they make their money, but depending on the price you may decide not to mess with it yourself. Just label the wires with tape when you find out.
2answers
1997 kis sephia wire harness
you can get a repair manual at your local parts store it will have your diagram you need !
5helpful
I need a wiring diagram for a fujitsu ten car stereo model 122001-33100151an serisl no. P9A00069
I have wiring diagram for FUJITSU-TEN model 12200-9880151, Toyota Part No. PZQ60-52020.
The pinouts may be similar to yours. if interested, e-mail [email protected]
Steven
I have a fujitsu am/fm/cd/ tape player out of a 93 camry and would like to put it in a 95 camry but the color code for the wiring doesn't match and thats what I need , can you help Thanks John
Hello jrhauber,
The '93 and '95 Camry have identical color codes. Likewise, the vehicle harness connectors are the same.
Car Radio Constant 12V+ Wire: Blue/Yellow
Car Radio Ignition Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amplifier Trigger Wire: N/A
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
You can purchase an aftermarket wiring harness that plugs into the OEM radio. The part number you need for a 1995 Camry is Metra 71-1761 available here for $9.99.
Hope this helps.
I need the wiring harness for my fujitsu ten stereo
What is the model # of the Fujitsu Ten Car Stereo. Do you still play cassettes? This would seem to be the reason for wanting to restore the unit - that and nostalgia. Once you have the model number you must do a search like;
Fujitsu Ten A230 harness plug. Also try Best Buy because they do a lot of car stereo installations. I just put my own unit in my Hyundai Tucson and bought my wiring kit from them; however you're going back to the 90's. I have another answer too, so let me know if this works.
Top Eclipse Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
