PUK (Pin Unlock Key) is required when a customer enters an incorrect PIN 3 times. After entering the wrong PIN 3 times, the card will be locked and the customer will need to get a PUK code from operator to unlock it. Once a PUK has been received it will need to be entered to set a new PIN code.
At the time when you enter a wrong pin number three times the phone asks you for a PUK number. The PUK code is generally eight digit number. This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to buy a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number. You can find the PUK code is in your SIM card documentation Starter Pack. If you do not have this then contact your phone service provider. Your cell phone service provider can give you the PUK code once they have confirmed your identity to prevent any stolen SIM access.
Inorder tosolve your PUK problem,
*kindly contact your service provider (customer care)
*Tell your phone number and they will give your PUK code
*Enter that code on your cell phone(Wall that ask puk code)
*Then your phone ask another pin code&to verify,there you can type your desired code(say 0000,00000,1234,12345).
* Then your phone will restart normally....
"IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
if it is asking for PUK code then contact your phone provider from another phone and ask them for the puk code by telling your blocked sim. If it is asking for pin code then try 0000 or 1234. In case both of these don't work then probably you changed the pin from default. Keep on trying different numbers till it gets blocked and asking for PUK code. Once it asks for PUK code just ask your phone provider and once you give the PUK code it will open.
*Enter that code on your cell phone(that ask puk code)
"IF YOU THING MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
