20 Most Recent Nokia 2600 Classic Cell Phone Questions & Answers
i am using a nokia 1280 i forgot my phone code safety..plss tell what i have to do
Nokia 2600... | Answered on Jun 20, 2018
GT Recovery for Windows Download: www.gtrecovery.net.
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices.
It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
Nokia 2600... | Answered on Jan 09, 2018
SECURITY CODE:
If it is lost nothing can be done. You need to flash your mobile at an authorized service center which will reset the mobile memory and also all the data inside the mobile will be lost.
Nokia 2600... | Answered on Oct 28, 2016
first get the settings from network service provider save them then ... go to configuration in your settings menu first ....
then go to personal configuration there you create an account for web and activate it.
select the personal config option and
then put ur service provider settings as default in the next one
select them and put activate default in all applications
then restart and start using..
Nokia 2600... | Answered on Oct 09, 2015
Hi you can purchase restriction code for your Nokia 2600 classis mobile from online providers like ClassicUnlocking.com for reliable cost ..You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim ...
Nokia 2600... | Answered on Dec 07, 2014
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Nokia 2600... | Answered on Oct 11, 2014
Dear Brother:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Nokia 2600... | Answered on May 05, 2014
clear the memory r memory is saturated
Nokia 2600... | Answered on Feb 28, 2014
mat khau bi doi lam sao de lay lai
Nokia 2600... | Answered on Feb 11, 2014
- To unlock you Nokia 2600 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nokia 2600... | Answered on Jan 19, 2014
You'll need to consult the manufacturers
Nokia 2600... | Answered on Jan 09, 2014
HI is your Nokia 2600 classic mobile is locked to network provider .Then you can easily unlock it using sites like OnlineGsmUnlock.com here they are rendering unlock code for all mobile models at reliable cost .You first verify that whether they are rendering code for your country and network provider .If yes then pay for it and unlock your phone ....Else if your phone is locked to security code then reset your phone using default security code ....
Nokia 2600... | Answered on Dec 25, 2013
no wifi
Nokia 2600... | Answered on Nov 17, 2013
Nokia 2600 Classic Cell Phone Logo
283 questions posted
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
View Most Popular
Classic Nokia
  • Classic Nokia
Most Popular Question
connect wifi s5233w
  • Cell Phones
