SOURCE: Hard drive erased? or Bad? maybe both?
Yes, HD is bad. When enabled, your PC sees it but takes along time finding contents and when contents found, will not be able to read it. If it contains important data, best is you use a data recovery software such as GetDataBack available at www.runtime.org. If recovered or will not allow you to, try deleting partition and/or reformat. Thereafter do a Scandisk.
On a similar problem, took me close to 48 hrs to recover movies and MP3s (at least most of them). Used Partition Magic to partition, format. and when I used Norton Utilities Disk Doctor, a lot of bad sectors showed up. I ended simply replacing since I already purchased another where the recovery was saved.
Hope this be of help to you.
I hope you have better luck.
SOURCE: hard drive worked on my pc. since i changed to a
copy all the files you need to a folder on the mac and then get the mac to format the drive
SOURCE: missing files after using the recover CD
In this case try some data recovery program to see if it can help rescue your data on your external.
SOURCE: To Whom it may concern,
kristy... is your computer a pc or mac ? if yours is a pc it does not generally use the same file system as a mac.
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hop this helps
Click permissions
hope this helps
Are the files write protected or just your usb drive
right click on the file select properties security make sure you have full control
Click permissions
hope it helps
You will have to be the computer administrator to change
click start control panel user accounts you should see a box with the administrator and the
guest account if you have made one click on the administrator this may vary depending on which operating
system you have
hard drive usually C: right click select properties there will be an array of
options select the security tab option then advanced make sure you have full
control in windows 7
windows XP
USB drives can be write-protected by modifying the
StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to
open the find dialogue box and type "usb device" or
"driverdesc" to open usb mass storage device or type "usb mass
storage device" in the search windows. And right click on it and delete.
This will set the policy value to 0. then insert your usb device. It will work
fine.
# Remember: do not delete any unknow files in the registry as this will make
some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
administrive tools computer management disk management right click on your
drive select properties then security select take full control in windows
7
fine.
also
- Click permissions
hope this helps
