20 Most Recent
Imation 4GB DEFENDER F100 FLASH DRIVE USB (51122278013) Questions & Answers
My usb imation 4GB PB1 is not format
1.) Plug it into a computer.2.) On the computer, go to Start, then Control Panel. 3.) When the Control Panel opens, go to Administrative Tools, then Computer Management. 4.) On the left-side panel of the new window, click on Disk Management. It will take a moment to load something in the middle panel.5.) In the bottom portion of the middle panel, scroll down until you find the Defender. Right-click on it, then select "Format" from the list. 6.) A small window will appear. Where it says "Volume label," type in what you would like to name the device. For the file system, select "NTFS" from the pull-down menu. Leave the "Allocation unit size" as default. Then click the "OK" button.7.) It will take a moment, but then it should be formatted for you.
I use my Imation 8
The entire procedure must be followed: click on the icon, wait for the message to appear, click on it, wait for the second one to appear, in it find your stick and click on it and finally wait for the message telling you that is now safe to remove the device. If you don't follow the procedure all the way the file system index is not corrected for the new files so it crashes the first time you connect the stick again.
If you get problems even after that then the memory chip in the stick is unstable - junk the stick and get a new one.
My usb locked with ImationLOCK
Proceed to the main screen of ImationLOCK (as per the picture below), click on where it's illustrated below as "log out".
You will then be instructed to enter your password. Keep in mind that you have six attempts to input the correct password.
If you do not input the correct password after the six attempts, the secure partition of the USB drive will reformat itself, destroying all of your files! You may click on 'password hint' for a hint to remind you of your password.
Not recognized
if you want to know if your flash drive is not defective plug it to other pc ,then plug it to your pc if not recognized maybe your usb port have a problem,be sure that your flash drive virus free.
Imation 8GB usb drive locked, how can i open it
5 Solutions to Remove Write Protected from Imation flash drive
- Solution 1:Turn off the write protected switch
- Solution 2: Clean up Imation USB flash drive
- Solution 3: Edit Windows Registry Key
- Solution 4: DiskPart command
- Solution 5: the Imation USB format tool
- Connect Imation USB with your computer
2/28/2024 3:36:15 PM •
Imation...
Answered
on Feb 28, 2024
No audio
Youtube has its own "mute/volume-control" level.
Unmute the video, and increase the volume-level.
6/21/2022 1:42:05 AM •
Imation...
Answered
on Jun 21, 2022
