I can't remove the print master platinum 18 from my computer (Window 7 64bit). Microsoft Security Essentials gives me the following message when trying to quarantine the infected file: The following error occurred: Error code 0x800700df. The file size exceeds the limit allowed and cannot be saved. Category: Trojan Downloader Description: This program is dangerous and downloads other programs. Please help
Well go ahead and download ESET - http://www.eset.com/us/home/products/antivirus/ and slect 30 day free trial. after that do a custom scan and do a deep scan of everything and after that it will tell you what going on. if indeed you do have a trojan that cant be handled i would recommend getting a reinstall of windows sometime to be all the way safe just get a new hard drive but go and do eset and do the deep scan and see where your at.
Testimonial: "Thank you for the help. I used ESET, and I was able to get the junk files (other adware/malware that were downloaded by Print Master) off my computer. I followed ESET with adwcleaner, and I was finally able to get rid of Print Master. No replacing the HDD for this girl :) Thanks again, you have no idea how long I was juggling with that program."
SOURCE: I have the Printmaster Platinum Version17 , I cannot save to pdf files?
1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution".
2. Go to File/Printer Setup/Printer Setup.
3. Under "Name" select Broderbund PDF Converter v2.10d
4. Next, go to File/Professional Printing.
5. Select "Save As PDF".
6. At the next screen, type the name of the PDF file you want to save in "Project Name".
7. Under "PDF Resolution", select 600 dpi.
8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents).
9. Click on the "Save" button.
10. PrintMaster will save the PDF file to the folder you selected.
11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
SOURCE: I installed Printmaster 2011 platinum
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
