I was out taking pictures today after putting a fresh battery in the camera. After a few minutes of taking pictures outside, the camera froze and will no longer work. Could this have anything to do with the temperature (20s)? Or is there another reason?
SOURCE: Camera won't take pictures
now u just need to replace the mainboard..... it´s pretty normal for then to go off if u don´t use it in the conditions they were made to.
SOURCE: Won't Take Picture Sometimes
I have the same problem with my D50. I believe it is caused by poor electrical contact between camera and lens. The contacts may be dirty but I have tried cleaning them and I still get the same error. Moving the lens often solves the problem. This led me to suspect that it is due to slight wear of the plastic mounting bayonet on the lens. This allows the lens to fall slightly and disengage from the contact pins. My 70-300mm lens has no problems since it only uses a few pins.
SOURCE: Camera Keeps shutting off
Have you changed the battery/batteries for another brand? I'm wondering if various brands react differently to extreme temperatures? Probably not the problem with your camera, just thought it might be worth a try!
SOURCE: nikon coolpix L4 won't take pictures & turns off
I have the same camera & personally, I hate it. My camera does that all the time, sometimes, it takes a while for the picture to actually take. Try holding down the button for a while, that's what I have to do with mine. The camera sucks up all the battery energy with only a few picture takes which I really don't understand. I think that's also why it's cutting off while you're using it. Does the phrase, "Warning: Batteries exhausted" sound familar, especially right before the camera shuts off? Oh, & before I go, my personal advice to you is: Get a new camera. I don't even know why I bought mine, soon I'm getting a new one. Yay. I hope this helped you, sorry about the camera problems. Much luck! :D
SOURCE: D50 (CHR) problem, I think temperature related.
Its temperature related the barreries dont operate below 0 %
