Nokia 5000d hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
This option resets some of the menu settings to their original values. It does not delete data that you have entered or downloaded, or affect entries in your contacts list.
In the standby mode, select Menu > Settings > Restore factory settings. Enter the security code, and select OK. See "Change lock code," The default code is 12345.
hello, if you want to restore your factory setting and the phone is not accepting the Nokia 12345 code then you have to copy out all the information you have on your phone then you will flash the phone. flashing the phone is like formatting the phone and after the flashing has been done all information will be wipe off on the phone. thanks for using fixya.
Sony says C31 is a Tape Loading Error. They suggested removing the camera
battery. Then re-connect and then re-set the camera back to factory
conditions. If it persists it may require attention. May also be a mechanical problem such as
is the back Rubber wheel in the proper place and the white plastic
lock is not there? flip the camera upside down it's come out
(the white plastic lock) then place it BACK
It may also be a bent lever. Try the factory restore first.
