Casio CTK-720 Electronic Keyboard with Stand, AC Adaptor and Instructional DVD Logo
A
Anonymous Posted on Jan 22, 2014
Computer does not have Ctk-720 driver
Computer Can't find ctk-720 driver
Andrew Rana
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 07, 2019
Andrew Rana
Contributor
Level 1:
Answers
Questions
0
Helped
819
Points
The driver that works for windows - 7 8 8.1 works with 10, download zip - extract, run dpinst.exe as administrator - https://support.casio.com/en/support/download.php?cid=008&pid=72 ctk-720
Reuel Teoh
Level 2:
Champion:
  • Casio Expert 411 Answers
  • Posted on Aug 03, 2014
Reuel Teoh
Casio Expert
Level 2:
Champion:
Answers
411
Questions
Helped
112776
Points
490
PC drivers available at Casio
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a MAC google casio driver for Macs by 3rd party.
5 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Sep 09, 2009
SOURCE: not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
Anonymous
  • Posted on Nov 30, 2009
SOURCE: how can i connect my ctk-720 to my mac
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Anonymous
  • 192 Answers
  • Posted on Feb 10, 2010
SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
  • 6688 Answers
  • Posted on Feb 24, 2010
SOURCE: my kids lost the driver cd for my casio
The Casio support site has a page to download the latest driver and software; once you download it you can install the file (and save to external media):
http://support.casio.com/download.php?cid=008&pid=340&rgn=1
I hope this helps.
Michial Gueffroy
  • 1140 Answers
  • Posted on Nov 11, 2010
SOURCE: i want driver for ctk-810
Try this link:http://support.casio.com/download.php?cid=008&pid=340&rgn=5
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Where can i get a ctk 481 driver
CTK 481 only has MIDI-IN and MIDI-OUT ports & no USB. So you need to buy a USB-MIDI interface (cable-like) preferably one that is class-compliant for you OS. Class-compliant device do not need drivers (PCs, MACs, IPAD).
How to fix ctk 7200 keyboard sdcard erorr
SD or SDHC memory cards must be between 2GB to 32GB
1GB SD card for earlier models or even 2GB SD formatted by earlier models are incompatible (folder structure has changed)
Ctk 5000 driver
I prefer, only in CASIO authorized service
Can't connect my ctk-720 to my mac
The Mac needs the driver, and you may need to select it in Chooser as well. If it is not on the instruction disk, it should be downloadable from the manufacturers website.
2helpful
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 • Casio Music
20helpful
2answers
How can i connect my ctk-720 to my mac & the garage band application.
Nov 28, 2009 • Casio Music
Casio Ctk 496 Electronic Keyboard with 61 Keys, drivers needed
Try uninstalling and reinstalling both the keyboard and the game. If that doesn't work then the keyboard may not be compatible with the software.
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
